pick up wiring help Les Paul
http://www-.luthiersforum.com/forum/viewtopic.php?f=10123&t=30781
Author:  owln [ Wed Jan 19, 2011 7:18 pm ]
Post subject:  pick up wiring help Les Paul
I hope this link will work for the photo, if not please let me know. I need too know how to hook up the pickups. Thanks for your time and trouble, Owln
Author:  peters instruments [ Wed Jan 19, 2011 7:31 pm ]
Post subject:  Re: pick up wiring help Les Paul
you need to ask a question to get an answer....
Author:  peters instruments [ Wed Jan 19, 2011 7:36 pm ]
sorry i did not see the comment on your attachment, take a look at this http://www.seymourduncan.com/support/wi ... h_2v_2t_3w
Author:  owln [ Wed Jan 19, 2011 7:45 pm ]
thanks for the link but I have 5 wires coming from the neck pickup and 3 from the bridge pickup.Just a little confused, I've looked at about all the wiring diagram I can find and none really tells me much. owln
Author:  Mustang_jt [ Wed Jan 19, 2011 8:50 pm ]
Your bare wire in your diagrams is a ground, so it just goes to the closest ground you can find. Your neck picup is a 4-wire humbucker and your bridge is a 2-wire humbucker. The 4-wire humbucker allows for coil splitting. If you don't know what that is, then you need to check with the manufacturer on their wiring because you need to link the two coils together making it a 2-wire. look at the diagram here http://www.guitarelectronics.com/product/WD2HH3T22_00/Guitar-Diagram-Gibson-2-Humbuckers-2-Volumes-2-Tones-3-Way-Toggle-Switch-View-Download-Free
You need to know which colors are your north finish and your south finish on the neck pickup, but your bridge has the coils linked inside the pickup. Hope that helps.
Author:  owln [ Wed Jan 19, 2011 8:55 pm ]
Thanks that has help a lot Best wishes and may God Bless. Howlin Owln
